07-12-2016 12:44 - edited 07-12-2016 12:44
I lost the clasp on my Surg and went to the site to look for a new one. None listed. So struck up a chat with support. Fitbit does not support parts, clasp, for the surg. As how I am out of my warranty only option is to take 25% discount and purchase a new devise! That is totally not acceptable. There is not a thing wrong with my current Surg, other than a missing clasp.
May be time to change products.
07-15-2016 11:16
07-15-2016 11:16
I found a third party that replaced the clasp. It fits perfect and it cost $1.95. If you break or lose the clasp try these folks Esslinger.com. You will need a 28mm clasps.
If the band breaks this is not a fix
Best Answer07-15-2016 11:16
07-15-2016 11:16
Best Answer07-18-2016 04:19
07-18-2016 04:19
@bill328 It's great to see you in the Community! So sorry to hear about the lost clasp and I appreciate your understanding in regards the warranty. However, I'm so glad to hear that you resolved the issue by replacing with a third party. Thanks very much for your suggestion and advice.
Don't hesitate to get back if more help is needed my friend and I'll be around! ![]()
