04-11-2016 14:32
04-11-2016 14:32
Best Answer04-11-2016 14:33
04-11-2016 14:33
Best Answer05-30-2016 23:47
05-30-2016 23:47
Best Answer07-26-2016 07:35
07-26-2016 07:35
Hey there @JanKosatko, that's correct, having your arms stationary will impact the reading. In this case another option is using Fitbit app feature Mobile Run. Working with the GPS sensors in your phone, MobileRun calculates distance, elevation, and pace for your walk, run, or hike. When the activity is done and you sync your tracker, you'll find all the data and a GPS map of your route in your exercise history.
If you wear your tracker while using MobileRun, the steps, active minutes, and calories burned that you see on your Fitbit dashboard come from the tracker. Otherwise your phone is used to calculate this data. During the workout you can view your elapsed distance, time, and average pace as well as use the music controls in the Fitbit app.
Give a try and let me know how it goes! ![]()
Was this what you were looking for? Vote for it and mark it as an Accepted Solution!
