02-09-2017 22:24 - edited 02-09-2017 22:25
My surge stopped syncing about 2 weeks ago with my iphone 6. I have gone through all the steps shown in troubleshooting and even had an online chat with support and went through the same steps with them. Still my surge won't sync so I have a watch that doesn't tell the right time and won't track my exercises and all the other bits
02-10-2017 01:17 - edited 02-10-2017 01:18
Have you done a restart? do it 3 times
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
You dont say if its phone or computer
Computer is the Dongle plugged in? If so Try a different USB port.
Here are some threads that might help
https://community.fitbit.com/t5/Flex/syncing-issue-with-my-Flex/m-p/1701255#M163030
Wendy | CA | Moto G6 Android
Best Answer02-10-2017 05:29 - edited 02-10-2017 11:05
Hey there @Michael_66! We're happy to see you here! As @WendyB mentioned when reconnecting your Surge with your phone trying multiple restarts helps a lot! I would also check for updates for both: your iPhone and Fitbit App. Is your phone's Bluetooth finding the Fitbit Surge? Are you getting an specif messages?
As mentioned before, some times after trying with the computer you get better results, this would be only to troubleshoot the issue. Do you have this option?
Please keep me posted!
Best Answer02-10-2017 05:40
02-10-2017 05:40
02-10-2017 05:47
02-10-2017 05:47
@Michael_66 wrote:
I can't use a computer to sync with as it doesn't have Bluetooth. I'm waiting for support to come up another suggestion or anyone else?
Regards
Michael
If you have a dongle you can plug it in to a USB port and sync with out BlueTooth on your computer
You will need to download the software though if you never have
02-10-2017 13:36 - edited 02-10-2017 13:43
I have tried the multiple starts, I have tried using a dongle, I have tried using my iPad, iPhone etc and they all now get stuck when I try to set up the device "We have found your Surge" and I get no further. I did manage to get to a page where you "enter the number you see on your Surge" but there is no number just the clock. I'm just going round in circles. I have had the watch for just over a year with no problems but now I'm running (no pun intended) out of patience
Best Answer02-11-2017 00:42
02-11-2017 00:42
:((( I got the same problem! Can not make it work again....downloade, uninstalled, reinstalled, both computer and iphone.....
Best Answer02-12-2017 16:56
02-12-2017 16:56
Having exhausted all different ways to try and get everything working, and spending time with technicians at Fitbit, the conclusion is that the watch is knackered. It's only 14 months old but the company say that is outside the warranty period so the only solution is to purchse another one. I accept that it's not covered by the warranty but I won't rush out and buy another one that again could ony last such a realtively short time. Thank you for everyones help on this. It's a shame we didn't have a better outcome
Best Answer02-14-2017 05:00
02-14-2017 05:00
My first pairing was almost exactly like this. I think my main problem at that time was a low battery on the Surge, but can't say for sure. Very frustrating.
Best Answer02-14-2017 05:37
02-14-2017 05:37
Mine has started having problems syncing. I have a PC with dongle and I have to hold the watch right up to the dongle to get it to sync. It I don't, it never finds it.
