05-20-2016 16:33
05-20-2016 16:33
05-20-2016 17:08
05-20-2016 17:08
Welcome to the community!
No, it's limited to one of each model. Any particular reason why you want two Surges on the same account?
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
Best Answer05-21-2016 06:28
05-21-2016 06:28
05-21-2016 14:24
05-21-2016 14:24
The reason I ask is because the Blaze is very similar in capabilities to the Surge. It does lack the dedicated GPS, but has connected GPS (get that information from your phone).
You can have both a Surge and a Blaze paired to you account. You can swap the bands on your Blaze; so you may pick different styles (classic, leather, or metal) and different colors. So it's easier to accessorize.
As for having a charged backup, I'd recommend getting a USB battery pack and bringing your charging cable on hikes/camping. You can actually pause your hike and connect it to power to get some charge on long hikes.
I hope this helps.
Best Answer05-21-2016 15:32
05-21-2016 15:32
Best Answer05-22-2016 00:43
05-22-2016 00:43
Hello @manolosf,
First allow me to say that I do not work for Fitbit, I'm merely an active member of the community, who is familiar with the products.
I agree with you that Fitbit has already solved the complexities of syncing multiple devices with one account.
I disagree with you that pairing multiple trackers of the same model would behave precisely the same as pairing multiple devices of different models. In my opinion, the former is significantly more work, more complex, and, no offense intended, for relatively little gain. Take it from someone who has three separate trackers paired to their account. Allow me to explain...
Syncing is the easy part of the problem, a far more complex problem is how you, the user, interacts with each device. Currently, the way Fitbit distinguishes between devices in all of their UI is by model, allowing multiple trackers of the same model will make all of your interactions ambiguous. For instance:
And these are just the ones that came to mind in the first five minutes. Are all of these ultimately solvable? Absolutely. However, it's going to take significant UI changes across the online dashboard, and the Fitbit Apps on several platforms.
The biggest reason why folks want more than one tracker of the same model is to accessorize. This is the reason why the new trackers (Blaze and Alta) have options for different bands... So in a way, Fitbit has solved this problem already. I could maybe see the desire to have a charged backup, but it's actually easier to carry a USB battery pack and the charging cable (you'd be surprised, it charges very quickly this way)... not to mention considerably cheaper.
Quite honestly, considering the new trackers have changeable bands. I don't believe that enabling this (multiple trackers of the same model) is worth all the work that they'd have to do to get it to work appropriately for, no offense, a pretty small set of customers.
Just my 2¢.
01-15-2017 17:46
01-15-2017 17:46
I also wish I could sync two fitbit devices of the same model to one account. I smashed my Blaze while mountain bike a few weeks ago and have since bought a new one. But since the crunched Blaze still works, I would much rather continue riding with that on my bike rides and wear the pristine no-cracks one for work etc. In fact, I bought the second one assuming that I would be able to use both! Tsk tsk....
