07-13-2017 08:50
07-13-2017 08:50
Whenever I pick my baby up (or grab items and hold them) my fitbit surge stops tracking steps.
It happens so much that I just put it in my pocket normally.
Please help because it's tougher and tougher to choose between having accurate step totals and picking my daughter up!
PS.. Sad that I have to explain that the last sentence is just a joke. If you can't handle sarcasm (or don't know how to) please don't bother responding.
Best Answer07-13-2017 11:41
07-13-2017 11:41
Wrist models will not count steps when holding on to things. Sorry.
The One sounds like a much better model for you if you are holding on to a lot of things.
Wendy | CA | Moto G6 Android
07-13-2017 11:41
07-13-2017 11:41
07-13-2017 11:54
07-13-2017 11:54
Really? So if you are holding a baby and walking that is not considered a step?
And if i put the baby (or groceries) down, will it pick up where it left off? Because it doesn't seem to and I have to continuously reset it.
Best Answer07-13-2017 12:14
07-13-2017 12:14
@Bankman1989 From what I've read in other threads the Surge uses an accelerometer to detect movement. If you are holding something and your arm is not swinging (the normal motion when you walk) it doesn't recognize that you are moving. I would think it should "pick up" where it left off. I'm curious. Do you just check the steps on the Surge display or also on the Dashboard after a sync? Welcome to the world of FitBit.
07-13-2017 12:45
07-13-2017 12:45
Great question. I notice that even after i put her down it still doesn't start back up. In fact i have even picked her up with the opposite hand and still have to re-set it.
I find myself putting it in my pocket (like now as I type this). I am ok with that I guess.
