09-14-2017
04:26
08:38
YojanaFitbit
09-14-2017
04:26
08:38
YojanaFitbit
Unpacked Surge, connected to Laptop, set up Fitbit account, now app asks for number on fitbit to enter onto PC, this is put in and surge is still stuck on configure screen. When I try to reset using home/select button does not reset stays stuck on configure screen.
Hi, @nick52 thanks for stopping by! A warm welcome to the Fitbit Community. ![]()
I'll be more than glad to help you with this! You mentioned Fitbit Charge 2 in the title of your post but the Fitbit Surge in the post. Would you mind confirming which one you're using? If your computer is asking the number to connect with your Fitbit again, must likely the set up process didn't finish successfully the fist time.
I'd recommend restarting your Fitbit tracker a couple of times and follow these instructions to make it connect with your phone again. If you prefer to use your computer, please try the steps in this post.
Give it a try and please let me know the outcome! ![]()
Thanks for getting back with the update @nick52! So glad to know you're back on track! ![]()
Please take a moment to visit our Discussions board where you will find other members sharing their experiences and tips. This is a really good way to stay motivated towards your goals. In case that you haven't do so, check it out! You might be interested in these topics: You know you're a Fitbit addict when...... or Looking for Fitbit Friends? Find some here!
I’ll see you around the Community! ![]()
