New in using fitbit
I want to track my workout and I don't want to wear my surge the hole day. In the other side I will track my swimming and running that will begin in spring. Is there anyone who can help me to do these with my fitbit surge??
3 REPLIES 3
first : read the user guide and the FAQ
http://help.fitbit.com/?p=surge
Welcome to the Community @Linus2016! I think that manually logging your activities would be a great option for those moments where you don't want to wear your Surge. To manually log your activities, do the following:
1. Go to the Activities page by clicking Log at the top of your dashboard, then click Activities.
2. Under Log Activities, click a common activity or search for your activity in the search box.
3. Select your activity from the search results. If the activity is not in our system, you have the option to create your own activity by clicking the Create custom activity text that will appear below the search field.
4. Enter the duration, distance (if applicable), and start time of your activity. You have the option to manually enter the number of calories burned here if you'd like to.
5. Click Log Activity. Your activity will now be visible and editable in the Logged Activities area.
Since your Surge is watter resistant, I don't recommend wearing it while you swim. This activity can also be manually added to your stats. I'm pretty sure that Surge will be your best tool for your runs.
Hope this helps!
Fitbit Community ModeratorVivian | Community Moderator, Fitbit
Did this help you? Help others by marking it as a solution! 🙂
Hope this helps!
