02-16-2016 13:18
02-16-2016 13:18
02-16-2016 15:15
02-16-2016 15:15
Nobody knows. When Fitbit releases one we will all know then ![]()
Wendy | CA | Moto G6 Android
Best Answer02-18-2016 19:40
02-18-2016 19:40
Best Answer02-19-2016 07:26
02-19-2016 07:26
What are you referring to in terms of an update?
Best Answer04-09-2016 11:26
04-09-2016 11:26
Hello there @NCJohnP and @SunsetRunner! That's true @WendyB there is not an estimated timeframe for the next firmware update. It seem you're having issues with your Heart rate readings. Since I don't all the details, I recommend taking a look at this information:
For daily usage, you can wear your tracker just like a watch, there should be a finger between your tracker and wristbone.
While exercising, I recommend wearing your tracker a bit higher. This is because your blood flow increases there.
Please let me know if this helped you.
