02-28-2016
09:30
18:41
EstuardoFitbit
02-28-2016
09:30
18:41
EstuardoFitbit
I'm sure I'm just a knucklehead... But my new Surge doesn't have a selection to edit the clock setting... Just has..Edit profile, Push Notifications, Heart Rate. Wth? What am I missing...? Thanks Suz
Best Answer02-28-2016 09:37
02-28-2016 09:37
Hello @Running-fit,
Welcome to the community!
If you're trying to pair your Surge through your phone's standard bluetooth settings, don't. Just install the Fitbit App, go to your account, and then add new tracker and follow the instructions from there.
The Fitbit App will manage the bluetooth settings on your behalf.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
02-28-2016 09:37
02-28-2016 09:37
Hello @Running-fit,
I hope this helps.
02-28-2016 09:43
02-28-2016 09:43
Best Answer02-28-2016 14:35
02-28-2016 14:35
Just don't get used to it. My Surge frequently fails to connect and, over time, it will become harder and harder to sync (this morning, alone, it took seven attempts of cycling my iPhone 6S and Surge before the device would pair (and, yes, I use the Fitbit app and have always done so)).
I really have never known a more frustrating device!
And to really 'put the icing on the cake': Yesterday I noted that the iPhone was syncing with the Surge and had recorded all the Surge's stats. This morning, after having struggled with trying to get it to sync, I saw that the Fitbit app on the iPhone had dumped the last three days' worth of information (and this is not the first time this has happened, either).
I'm going overseas soon so am waiting until then to finally get rid of this Fitbit device. Buying the Surge is turning out to be one of the least-impressive decisions that I have made.
02-28-2016 16:59
02-28-2016 16:59
@SunsetRunner,
For whatever it's worth, the steps show up on your profile over the last three days. This means that you still got credit for all the steps, they're just not displayed by the Fitbit App on your phone. Yes, the latter should work, but at least you need not worry about whether or not you've lost those steps.
02-28-2016 23:57
02-28-2016 23:57
Best Answer04-26-2016 13:10
04-26-2016 13:10
Hey @Running-fit, It's nice to see that @PureEvil helped you to set up your Surge tracker! @SunsetRunner, thank you for your time on this. I'd like to know if you already tried to set up your tracker as a new device. You don't need to remove the tracker from your accout. Since you mentioned you're mentioning you have an iOS device, these steps may help:
Keep me posted!
