The 24 hour clock shouldn't be an issue as you can select this in your profile settings at https://www.fitbit.com/user/profile/edit . Once changed and saved the next time you sync your Surge will be updated.
The second hand is more of an issue and there have been many posts from people wanting this. Someone has created a feature suggestion for it which you may wish to vote for:
Best AnswerAs the person posting the reply correctly elaborated that adding a second hand will cause a drain in the battery.
However, there is an indirect way to make use of the timer for people in medical field who needs the second hand to check the patient's heart rate. My wife works as a nurse. She has created a timer for 15 seconds which is adequate to check the patient's heart rate. She flicks the timer, starts it and surge vibrates when the 15 second is over (enough time to get the heart rate times 4). The beauty of the thing is that the 15 second set by the user is retained. There is no need to be set it again. Even though it means pressing the button couple of times to get the timer started. Better than wearing analog watch and smart watch (which is not that smart yet)
