03-01-2016 12:01
03-01-2016 12:01
Anyone having issues with Surge and loss of Iphone6 text and call notifications? I can't determine when my Surge lost that capability, but I have tried everything I can think of today to no avail. Have uninstalled, reinstalled device, rebooted phone, checked all notification settings on Iphone are correct, all day sync is on, have uninstalled and reinstalled the APP and re-added my device, Surge bluetooth is active, Surge Classic connection is active, still...nada.
One of main reasons I got the Surge was for this functionality, so need a fix. Please let me know if you have any input. TIA.
Best Answer03-01-2016 14:07
03-01-2016 14:07
Fixed with Fitbit support. May have just been doing things out of order. Power down Surge. Wait 10 secs. Turn back on. Turn off Bluetooth on iPhone. Wait 10 secs. Turn bluetooth back on. It automatically reconnected to Surge. I had to manually reconnect to Classic. (I had done this multiple times previously but order of steps must have just been different.) Text notification came through immediately following these simple steps. 🙂
03-01-2016 12:25 - edited 03-01-2016 12:28
Try rebooting your Surge klaws,
Press and hold the Home and Select buttons (left and bottom right) on your Fitbit Surge™ for 10 to 15 seconds, until you see the screen flash or start to dim.
Let go of the buttons.
After your screen turns completely off, wait 10 seconds and press the Home button to turn your Surge back on.
If this doesn't help, try "forgetting" your surge as a device under your iPhone bluetooth devices in settings. Turn Bluetooth off (after forgetting the device), then back on and selecting your Surge anew when your iPhone finds it to get a fresh request to re -pair.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
03-01-2016 12:46
03-01-2016 12:46
No luck but thanks for those suggestions. I have tried those, and did just try again. Still no notifications.
Best Answer03-01-2016 12:54 - edited 03-01-2016 12:56
Contact the fine folks on live chat and let them know all these steps you tried, - be sure to come back and let us know what worked...
The main doublecheck will be that you have:
Allow notifications - On
Show in notification center - On
WmChapman | TX
03-01-2016 14:07
03-01-2016 14:07
03-01-2016 14:10
03-01-2016 14:10
Exactly!
Well done klaws, it is all about the order.
WmChapman | TX
17:42
- last edited
7 hours ago
04-29-2016
17:42
- last edited
7 hours ago
Great news @klaws! Thank you for taking your time to share the tips that made your notifications work. I appreciate the time you took to work on this and share the solution with our friends. I'm pretty sure this information will be much appreciated. I just marked it as solution to make it more visible for our friends. Thank you for your help @wmchapman!
Have fun!
05-04-2016 12:04
05-04-2016 12:04
I have same issue, and none of the suggestions posted have resolved it. It did work but not sure at what point it stopped. I did get a replacement Sruge when my old unit's screen cracked.
I tried all of the suggestions posted here, and checked my settings on both iPhone and Surge, but still no luck.
Thoughts?
Best Answer05-11-2016 17:16
05-11-2016 17:16
Hi @PSBrawner! At this point I highly recommend contacting Support, they'll be happy to give you the hand you need.
11:53
05:11
07-31-2016
11:53
05:11
Surge not being notified when texts arrive and does not vibrate when 10000 steps achieved. Have switched on and off both surge and bluetooth, as directed further down the string, but no joy...
Moderator edit: Format
Best Answer08-12-2016 05:15 - last edited 7 hours ago
It's nice to see you around the Community @deedee27, hope you're doing good today
! I'm sorry to hear about this, if you've tried the restart that my friend @wmchapman shares here along with the steps that worked for @klaws (she shares them in her previous post); but they didn't work for you I'd recommend getting in touch with Customer Support directly.
Don't forget to mention the steps you've done so far to avoid getting the same ones, I'm pretty sure they will figure out where the issue is coming from.
Happy stepping!
Best Answer08-22-2016 16:40 - edited 08-22-2016 16:42
Fitbit Support was no help at all. BUT, this post by wmchapman was right on the money. Totally works now!! I told the tech they needed to reference this post in the future, since I wasted 50 minutes on the phone with them. Allow Notifications and Show In Notification Center. Yes!!
Best Answer08-23-2016 07:45 - last edited 7 hours ago
Yay @BillBergstrom
! Music to my ears!
Hope to see you participating in the Community more often since I think it would be awesome for you to explore our Community, so you can go ahead and log to any of the topics that might be of your interest in our Discussion boards. Feel free to comment and contribute with your knowledge and experience.
Happy stepping my friend!
