11-28-2016 22:21
11-28-2016 22:21
Best Answer11-29-2016 03:32
11-29-2016 03:32
I’m not sure what you mean by "not charging everyday": do you connect it to the charging cable everyday, but sometimes it’s charging, sometimes not? If so, have you checked the golden connectors on the back of your Surge? They may be dirty and/or worn, which may prevent good contact with the pins of the charging cable. I sometimes need to move a little bit the head of the charging cable for good contact to happen. I do it until I see the flash symbol on the Surge display (telling me it’s charging). Then, I leave it alone and try not to move it at all.
Dominique | Finland
11-29-2016 13:05
11-29-2016 13:05
11-30-2016 14:26
11-30-2016 14:26
@Dominique Great troubleshooting! Thank you! ![]()
@zoest01 welcome to the forums! Please give it a try and then post back with the outcome. In case you need further assistance or the troubleshooting doesn't work then I recommend contacting our Support Team. They definitely have the proper tools to take a deeper look into your tracker's behavior.
Good luck!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
