04-21-2016 14:44
04-21-2016 14:44
04-22-2016 06:17
04-22-2016 06:17
Check your Sleep Tracking settings (Settings page. Devices tab). If it's already "Normal" then... it doesn't seem there's an even more resistant setting (yet). Maybe someone added that as a feature request, and you can vote for it?
04-22-2016 06:21
04-22-2016 06:21
Yep, set to normal - I played with setting it to sensitive and it halved my sleep! Normal is more realistic for what is happening. Seems to work well when I'm actually sleeping... Just not so much when I'm taking it easy in the evening.
04-22-2016 06:38
04-22-2016 06:38
My device does a pretty decent job tracking my sleep. When I look at the HR track from the previous day, there is a decernable difference between "evening relaxing" heart rate of mid- to upper-50s and "asleep" heart rate in the upper-40s to low-50s. Not sure if Fitbit is using this data to track sleep or if it's purely based on some accelerometer/stationary basis.
04-22-2016 07:51
04-22-2016 07:51
My resting pulse has been a bit nuts since getting the Surge. It started with a pretty consistent downward trajectory as I was running a lot more, then I got a lung infection and resting pulse rocketed, now the resting pulse is going down again. When I was sick, it could correctly detect sleep despite a pulse that hit 175 for about half an hour (seriously; it was a heavy dose) and on subsequent nights ranging from 60s to 100s.
Based on that, I'd say it must primarily use accelerometer for movement instead of just pulse.
04-26-2016 03:33
04-26-2016 03:33
I guess I should consider myself fortunate; my Surge nails my sleeping patters almost spot on. That's good because I have severe sleep apnea and use a CPAP when I'm in bed; even still, I can see my sleep pattern change as the seal on my mask ages and starts to leak.
04-26-2016 03:36
04-26-2016 03:36
@GaiusCoffey wrote:My resting pulse has been a bit nuts since getting the Surge. It started with a pretty consistent downward trajectory as I was running a lot more, then I got a lung infection and resting pulse rocketed, now the resting pulse is going down again. When I was sick, it could correctly detect sleep despite a pulse that hit 175 for about half an hour (seriously; it was a heavy dose) and on subsequent nights ranging from 60s to 100s.
Holy crapski, a resting pulse of 175 while you were asleep?!? That's seriously scary stuff; I get nervous when my pulse gets above 40 when I'm sleeping.
04-26-2016 03:40
04-26-2016 03:40
Yeah, it was not a good week - turns out lungs are quite important to general well being - antibiotics sorted it though.
04-26-2016 03:52
04-26-2016 03:52
Glad things are working out for you. I'm curious, what is your normal resting and sleeping heart rate range?
04-26-2016 04:08
04-26-2016 04:08
Still in flux, but I think somewhere between 60 and 70 is about normal.
04-26-2016 04:37
04-26-2016 04:37
Wow, huge improvement; glad you recovered well. 🙂
05-02-2016 01:55
05-02-2016 01:55
