07-19-2016 07:38
07-19-2016 07:38
Two questions really. Sorry. How do I get notifications from Viber, Whatsapp and facebook on my surge. Secondly, is it possible to have different stride lengths for treadmill running and actual running? They are clearly going to be very different. The distances my surge is registering is a lot less than the treadmill says. Cheers guys
Best Answer07-19-2016 07:41
07-19-2016 07:41
When you say "actual running", do you mean like outside with "Free Run" (which implies GPS tracking) enabled?
If so, then the stride setting is ignored when you're running outside. Said another way, you're probably good to go if you set your stride length to match what you do on a treadmill.
Best Answer07-19-2016 08:12
07-19-2016 08:12
Best Answer07-19-2016 10:15
07-19-2016 10:15
@Johnnyw75 wrote:
Thanks for the reply. Seems reasonable but won't my general calories burned by walking be affected too?
Sent from Outlook
With your Surge you can walk in two different modes:
