09-11-2021 06:25
09-11-2021 06:25
Hi guys,
I've just had to replace my band on my Surge and bought a cheap one off Fleebay, but it doesn't click on, it doesn't push all the way upto the screen, and it seems too big so it protrudes upwards, isn't flush.
Can anyone recommend a good replacement that fits like the original, that's not silly money.
Cheers,
Jason
Best Answer09-11-2021 10:12
09-11-2021 10:12
Not necessarily a recommendation, but Amazon has many third-party bands for all Fitbit models at reasonable prices.
Best Answer09-15-2021 02:28
09-15-2021 02:28
Hi Johnny,
Thanks for replying. I do want a recommendation as the straps look identical by eye, but are very different when fitted.
Cheers,
Jason
Best Answer09-16-2021 16:03
09-16-2021 16:03
Hi, I got mine on Amazon and it worked fine, the main key make sure the watch part is clean and to use a small amount of rubber cement and let it sit over night. I followed the instructions and worked fine
09-19-2021 12:01
09-19-2021 12:01
@runswithcows rubber cement isn't your best option, B-7000 is.
@JMegson yes, they're mostly all just copies of the original. some fit horribly, some perfectly. I use original authentic Fitbit bands, from SanFran when they stopped selling Surges. the original ones I purchased in bulk are strictly black, so when I want colorful bands like red, blue, grey, etc. I've used the aftermarket ones. if you don't need an alternate color, there is a vendor in China on eBay that sells authentic Fitbit items. I don't know if appropriate to share links here, but you're welcome to send a private message.
