03-13-2016 16:31
03-13-2016 16:31
I got cought out in a bad rain storm. I put my surge in my pocket but it still got wet. It worked fine when I got home but after about an hour it started vibrating and the screen was totally blank but the green lights were still flashing. I plugged it up to the computer and I tried to reset it but nothing is working, please help
Best Answer03-13-2016 17:03
03-13-2016 17:03
Best Answer03-13-2016 17:19
03-13-2016 17:19
Best Answer03-13-2016 17:25
03-13-2016 17:25
Best Answer03-13-2016 17:36
05-04-2016 01:21
05-04-2016 01:21
Same thing just happened to me yesterday. Only part of the screen lights up and it looks all wonky. It seems to still track everything just fine, but I can only tell by syncing it to my phone. It wasn't even a bad rainstorm! Just a normal one, monsoon season hasn't hit in Korea yet. I've only had this thing six months, I'm pretty upset that something so expensive could get ruined by a little bit of rain.
Best Answer07-17-2016 11:31
07-17-2016 11:31
Hi there everyone @AVasyuta @tinagunn211 @SunsetRunner! Good to see you around!
I would recommend putting your tracker in a bowl with rice for it to absorb any moisture inside the tracker.
If after 24-48 hrs it is still not responding, I would recommend getting in touch with the Support Team for them to help you with this.
Let me know how it goes!
