07-20-2017
10:24
13:13
AndreaFitbit
07-20-2017
10:24
13:13
AndreaFitbit
A red light is showing on my Surge that I have never seen before. I tried to shut down but all I am seeing is the Fitbit logo and no restart. Anyone know what this means or how to fix it?
Best Answer07-20-2017 14:08 - edited 07-20-2017 14:11
Hey hey hey, it's nice to see you around @Andrew654!
I have moved your post to the Surge board in order to assist you and other Surge users can check this response. It's a shame that your Surge is showing a red light on it, let me help you.
First, check if you have the latest Firmware update. If you do, restart your device following these steps:
Then sync your tracker with the instructions from this help article: http://fitbit.link/1RlUVtX.
You can check your email address, you'll receive a message with instructions.
Catch you later!
07-21-2017 08:29
07-21-2017 08:29
Thanks for the input but when I press the 2 buttons as instructed the red light goes out and the screen slowly loses the Fitbit logo and goes blank. When I release the buttons the screen immediately shows logo and red light turns back on. So I have not been able to shut down my Surge, any other suggestions?
Best Answer07-21-2017 13:32 - edited 07-22-2017 04:52
Thank you for coming back and for troubleshooting your issue with the provided instructions @Andrew654.
Please check your email's inbox, you'll receive instructions to continue resolving this issue soon!
Let me know how it goes and if you need more help! ![]()
07-25-2017 09:32
07-25-2017 09:32
I'm having the exact same issue and also cant get the red light off. I followed the above instructions and that has not remedied the problem. Any other solutions?
Best Answer07-25-2017 13:51 - edited 07-25-2017 13:57
Welcome to the Forums @Gsusfriek1! It's a shame to hear that your Surge has a red light on its screen too. Thank you for following the troubleshoot steps from my previous post. Since they didn't work to turn the red light off, I have created a case on your behalf, please stay tuned to your email's inbox to get instructions.
Let me know how it goes. Have a nice day! ![]()
07-29-2017 13:46 - edited 07-29-2017 13:51
I too am having this issue with my surge & the red light staying on after re-starting it & re-syncing...... it's been on for a week. I have checked my Fitbit app for updates & it's all as it should be? Any further info on how to get rid of the red light please?
Best Answer07-29-2017 14:48
07-29-2017 14:48
@W7LDV If your Surge is within the warranty period then contact Customer Service. If it is not under warranty try draining the battery to zero. This usually takes 24 hrs after the red LED goes out and the display goes blank. Once the battery as at zero plug it in to charge. If the red LED comes back on then there is no fix. However. If all other functions of the watch work then you just have to charge the watch more often and put some black electrical tape over the LED. Best of luck to you.
Best Answer07-31-2017 14:42
07-31-2017 14:42
Hello, I'm having the same issue with my surge. The red light is on and when I try to turn my watch off it won't turn completely off and the red light is still on. Not sure what I'm doing wrong! Help!!
Best Answer07-31-2017 15:59 - edited 07-31-2017 16:01
@Foley92 Hi Foley92. You're not doing anything wrong. The Red LED should not be on. If your Surge is within the warranty period then contact Customer Service. If it is not under warranty try draining the battery to zero. This usually takes 24 hrs after the red LED goes out and the display goes blank. Once the battery is at zero plug it in to charge. If the red LED comes back on then there is no fix. However. If all other functions of the watch work then you just have to charge the watch more often and put some black electrical tape over the LED. Best of luck to you. Welcome to the World of FitBit
08-01-2017 14:22
08-01-2017 14:22
Welcome to the forums @W7LDV and @Foley92!
I'm sorry to hear your Surge has a red light on too. Since you have already tried all the troubleshooting steps from my Previous post I have created a case on your behalf. Stay tuned to your email address for instructions.
@VF31AE3, thank you for all your help! ![]()
See you around!
09-26-2017 18:28
09-26-2017 18:28
I am having the same red light problems as the rest which appears to have come with the software update. I have shut the phone off, shut the fitbit device off many times and tried linking via the computer. I will drain the battery, but wanted you to know that things aren't looking good. Can't fitbit just write a script under the settings to disable that light?
Best Answer09-27-2017 09:32 - edited 09-27-2017 10:10
It's nice to see you in here @MrPetie. Let me help you with the red light on your Surge issue. Has it disappeared or does it still show on your Surge?
Thank you for sharing the steps you have already followed in order to correct this error. Please follow the instructions from my previous post and let me know if the issue persists.
Currently there isn't a script to disable this light.
Catch you later!
09-30-2017 11:29
09-30-2017 11:29
Anyone come up with fix on red light issue?
Best Answer09-30-2017 14:08
09-30-2017 14:08
@Gjallen1860 The only potential "Home" remedy is to run the battery to zero (24 hours after the display goes blank). Recharge and restart. If the red LED returns then you just have to deal with it and the short battery charge life. Good luck.
Best Answer09-30-2017 18:30
09-30-2017 18:30
Best Answer10-04-2017 05:35
10-04-2017 05:35
Welcome to the forums @Gjallen1860!
Were you able to remove the red light on your Surge? Did you follow the instructions from my previous post? Please let me know, so I can open a case for you.
@VF31AE3, thank you for your help! ![]()
Thank you for visiting our community! ![]()
10-07-2017 08:19
10-07-2017 08:19
I too have the red light and tried the tip posted to turn it off but I also am not able to get the device to turn off.
I am using the up to date operating system 16.34.5.14
What is my next step?
Best Answer10-07-2017 08:40
10-07-2017 08:40
@KristinS1 If the Surge is still under warranty then give Customer Service a call. If not, then allow the battery to completely drain. This is about 24 hours after the red LED goes out and the display goes blank. After. Recharge and restart. If the LED returns then it's something you'll have to live with. You will have to charge more often as the LED drains the battery faster. You can also put black tape over it to hide the light. Good luck.
Best Answer10-10-2017 06:10
10-10-2017 06:10
It´s nice t see new members in here @KristinS1! It's odd that the red light on your Surge hasn't turned off after restarting it and trying to turn it off.
I've created a case for you and you'll receive an email from our support team soon.
Once again, thank you for your help @VF31AE3. Nice advise! ![]()
Thank you for visiting the forums!
