07-01-2017 13:11
07-01-2017 13:11
Got a replacement Surge (due to strap breaking fault) plugged in to charge up, now I can't even get past the configuration screen, tried plugging into PC with Fitbit app open, tried connecting to app on iPhone, tried holding both left button and bottom right to restart but nothing working. A little gutted as I love my Fitbit......... help
07-01-2017 13:13
07-01-2017 14:41
07-01-2017 14:41
Can anyone help ? Even from Fitbit themselves ?
07-01-2017
14:59
12:06
YojanaFitbit
07-01-2017
14:59
12:06
YojanaFitbit
I was having the same issue, until customer support suggested a full two-hour charge, and then with their help, and whatever settings they made at their end, my Surge is now working.
Try a full charge (2 hours) and if that doesn't help, chat with someone in customer support. ( they were great.)
Moderator edit: Word Choice
07-15-2017 12:25
07-15-2017 12:25
How you doing @Taff_Williams? Thanks for joining this family! ![]()
Thanks for the piece of advice @TXAnneV.
@Taff_Williams I think that you need to use the computer using the Fitbit Connect program via Wireless Dongle. Please charge your Surge and if you can leave it connect while you're setting it up, it'd be great! If it is not connecting you can try to restart it a couple of times.
Give it a try and let me know how this works! ![]()
10-22-2018 03:17
10-22-2018 03:17
I just had this problem too - both my iPhone and PC were still looking for the old fitbit. Go to "Add a Device" section on either device. The next thing that happens is it asks you if you want to forget your old device and add a new one. After this it was plain sailing.
10-31-2018 12:25 - edited 10-31-2018 12:26
Hi @conrosco, I'm glad to see you here! Sorry about what happened to your Surge!
Thanks for the steps that you've tried already. Why don't you try the following steps on your Surge to see if this help:
Then try to add set it up again. Hope this helps, if not let me know so we can get in touch with customer support.
I'll be around.
