08-13-2018 14:38
08-13-2018 14:38
Hopefully some of you can help, I will try and keep this simple , please more for my benefit, got a replacement Surge and would like to retain all data from old Surge , also strugling to work out how to set up replacment watch
Hope all makes sense
Alister
Best Answer08-14-2018 00:03
08-14-2018 00:03
To set up your replacement go into the account section of the app (the icon looks like a business card).
Select "set up a device" and then select "Surge". It will ask you if you want to replace your existing Surge. Just say yes and follow the prompts.
All your data, settings, badges etc will be retained.
