Unfortunately the bands on the Surge are not replaceable as the electronics are built into it. To replace the band you need to replace the entire thing.
Are you still within warranty? See www.fitbit.com/returns for details.
If so then you could contact customer support to see if they will replace it for you:
Thanks for joining us @Goldberg16, welcome to the Forums! I'm sorry to hear about your band, for hardware issues, it's best to contact Customer Support as @SteveH mentioned. They will be more than glad to help you with this! ![]()
Keep me posted on the outcome. ![]()
