06-26-2016 13:09
06-26-2016 13:09
Best Answer06-27-2016 00:01
06-27-2016 00:01
It's worth checking that your timezone is still set correctly in your profile settings at https://www.fitbit.com/user/profile/edit
Best Answer08-20-2016 01:56
08-20-2016 01:56
My Surge clock is 16 minutes behind time. No pressing of buttons allows me to reset the time. Is this a design fault ro should I ask to have my Surge replaced? Help please!
Best Answer08-20-2016 02:43
08-20-2016 02:43
There are no settings for the time as it should update automatically every time you sync. Does your Surge seem to be syncing ok? Is the time correct on the device you sync to?
