02-07-2016 14:39
02-07-2016 14:39
10:29
07:03
02-08-2016
10:29
07:03
@Monchie Welcome to the Fitbit Community! Try to log out from the app, reboot your phone, and log back in. If it is still not showing; go to your phone settings, scroll until you find the Fitbit app and tap on it, then under "location" tap "while using the app" or "always". Try to use it again. There is also a third party app that can do this for you, it is called MapMyRun and you can link that with your Fitbit tracker.
Let me know how it goes! ![]()
Best Answer02-08-2016 23:27
02-08-2016 23:27
02-09-2016
09:45
07:02
02-09-2016
09:45
07:02
@Monchie I hope you're doing well! Thanks for sharing the tip that worked for you. I'm glad to hear that the routes are now showing on the app.
Also, make sure to check the Discussions Board as you will find tons of interesting things there. Feel free to post on any thread.
Thanks for joining us! ![]()
