Hi @Billyhersh! Please receive a warm welcome to the Fitbit Family! It's great to see you participating in our Community! ![]()
Please make sure that you're device is running the latest update and restart it, you can also restart your Fitbit Surge before using it again. Galaxy Note 8 is not in the list of compatible devices with Fitbit, which means that even if you download the Fitbit App, not all the features will work flawless.
Some users have reported that they were able to sync with this type of devices, but you will need to give it a try.
Keep me posted.
Best AnswerI have tried everything! I guess they don't and won't support it. $$$$$ rule$
Thanks for your comments @Zalim and @Billyhersh! As mentioned before when it is not a compatible device it might work some times but some others it can have issues connecting.
At this moment we don't have more information in regards when the list will be updated, but stay tuned! We usually have information posted in the Community. Remember that you have the option to use a computer or any other compatible device in the meantime. You will find information on how to connect in a computer in this master post.
Let me know if you have questions about it.
