08-12-2017 10:43
08-13-2017 10:30
08-13-2017 10:30
Hi @Calisto,
If you go into the settings for the tracker inside the app, you'll see "Clock Display". If you select that, you'll see all the options you have currently for stats on the screen. My favorite shows time, heart and steps. Hope this helps.
Best Answer08-12-2017 14:57
08-12-2017 14:57
Welcome to the forums!
There is no way to do that I'm sorry.
Hope to see you around the forums! Join in on the discussions forums!
Wendy | CA | Moto G6 Android
Best Answer08-12-2017 23:48
08-12-2017 23:48
08-12-2017 23:48
Best Answer08-13-2017 10:30
08-13-2017 10:30
Hi @Calisto,
Best Answer08-13-2017 10:55
08-13-2017 10:55
Thanks for suggestion
i Will apply thank You again
