In the hope this may be a software glitch you could try restarting the Surge using this procedure:
https://help.fitbit.com/articles/en_US/Help_article/1186/
Give it a few tries though as it doesn't always work first time.
If that doesn't fix it then it's probably a hardware issue. If you live within the EU then you will still be covered by the 2 year warranty (outside the EU it is just 1 year) and should contact customer support:
It's great to see you in the Community @Daisydrosa! I'm sure your Fitbit Surge will be back on track after trying @SteveH's suggestion, but if you're still having issues with it, feel free to reply back. ![]()
In case that you don't have more questions, I also invite you to visit our Discussions board where you will find other members sharing their experiences and tips for an active lifestyle.
Thanks for taking a break from stepping! ![]()
Best AnswerMaybe you bumped the watch somewhere?
I haven't had mine for too long but I don't think the quality of the screen is that good... Meaning that if you touch it with a little force it might break but I am not sure yet.
However, I doubt that the issue could occur from a random bump. Hope you can find a way to resurrect your device and start using it again
Thank your very much for jumping in @SunsetRunner, I'm glad to see around that often! ![]()
The screen of the Surge is very resistible but in case that you need type of help or notice any odd behaviour on your band, feel free to contact Support for further help! ![]()
Hope this helps and let me know if you need anything else! It's great to have you in the Community! ![]()
