09-07-2017 14:42
09-07-2017 14:42
My Fit bit surge doesn't seem to be tracking sleep correctly. Last 2 weeks show only one or two hours sleep with the tracking only starting early in the morning.
Best Answer09-08-2017 03:14
09-08-2017 03:14
It is possible that the sleep tracking setting has changed from Normal to Sensitive. Check the setting and change it to normal and it will track the full sleep. Sensitive tracking will show your true deep sleep time only. However you can still track sleep by looking at the log and checking the sleep time and wake up time. Hope this helps.
