02-23-2016
04:09
15:14
AngelaMa
02-23-2016
04:09
15:14
AngelaMa
Hello dears.
I need some help about the results on tracking sleep results that are shown on the Surge app.
I'd like to clear some issues. First, what exactly means "restless"? Would it be compared to "light sleep"? Better, what stage of sleep? Is "asleep" the REM stage?
What is the better (ideal) results that shows on the Surge app?
Thanks
Luis Pessoa
Moderator edit: format
Best Answer03-25-2016 16:33
03-25-2016 16:33
Hello there @Alexpessoa! Thank you for your question, I'm pretty sure you'll find all the information you need about your sleep activity on this article.
Hope this helps.
