01-01-2016
22:50
07:18
CindyFitbit
01-01-2016
22:50
07:18
CindyFitbit
I just got a brand New surge fitbit, I am trying to set it up but the watch is stuck on configuration go to fitbit.com/set up. I down loaded the app on my phone and turned my blue tooth on. Still not working. What do I do?
If the setup is not working on your phone it might be because it is not supported by fitbit. You can check here:
Are you able to setup the fitbit on a computer using the wireless dongle and downloading the software from www.fitbit.com/setup ?
How far through the setup process did you get before it stopped?
Best AnswerHi Malitick,
I'm having the same issue, where did you locate the olod Fitbit Connect Software that ended up working for yours?
Thanks.
