01-19-2016 07:49
01-19-2016 07:49
So I pretty much love my fitbit, and I bought the Surge right after Christmas. Four days ago it completely stopped tracking sleep and it's driving me crazy. I changed the sensitivity, that did not fix the issue. I've re-started it, and that did not fix the issue. Any other options out there?
01-19-2016 09:42
01-19-2016 09:42
@glitchxoxo, sorry to hear that your device isn't working as it should. Can you try initiating the start of your sleep on your phone; and then when you wake up, hit "I am awake". Then see if your device monitored your sleep. Please let me know what you find.
Nick | Washington
Surge, Blaze, Flex 2, Alta HR: - iPhone 7, Windows 8/10, Macbook Pro
Please mark posts as solved if you got the answers you needed, or visit the Fitbit help site for further assistance and information.
01-19-2016 09:42
01-19-2016 09:42
Nick | Washington
01-25-2016 02:28
01-25-2016 02:28
Once I did that, it started tracking automatically again. Thanks!
Best Answer01-26-2016 11:33
01-26-2016 11:33
I have the same problem with the Surge. It tracked my sleep for about 25 days and then just quit. All other functions work well. After reading the community issues, I restarted the Surge with no luck. Then I did the manual start and stop and all I got was a straight line - no restless or awake times. I really like the Surge, but the sleep log is imortant to me. This has been going on for 4 days. Any help would be appreciated.
Pete
Best Answer01-26-2016 13:21
01-26-2016 13:21
Please disregard my last post. I just did the "Dongle trick" and now the sleep tracker is working. I did lose 2 days of tracking, but by doing the above recommendations a couple of days ago, the sleep was recorded - it just wasn't showing up until I synched with the dongle.
Pete
Best Answer06-02-2016 01:57
06-02-2016 01:57
My surge has stop tracking sleep. And I noticed your 'dongle trick' message! Can you tell me what that is and how it works! Not tracking sleep is making me lose sleep ![]()
06-29-2016 11:02
06-29-2016 11:02
My iphone 6s plus no longer shows the option of sleep tracking in the app, and it no longer records sleep in the fitbit online dashboard.
Best Answer06-29-2016 11:17
06-29-2016 11:17
I figured out what happened in my case, my new phone had lost the device. I setup again and all is good
Best Answer08-13-2016 06:47 - edited 08-13-2016 06:47
It's great to see you guys around @MIAOHLB @Mardai24, hope you're doing good! The sleep tracking should be autmoatic, meaning that it should arrive on your Dashboard pretty soon after you wake up. If it isn't, there are a few things we may try to ensure we're troubleshooting as best we can:
I'd recommend restarting your Surge by following the steps that my friend @SunsetRunner shares in this post to make sure it's transferring the data correctly.
Also, please check if your Fitbit app is running the latest version. Keep in mind that old ones might cause issue like this.
Hope this helps!
Best Answer09-10-2016 02:56
09-10-2016 02:56
Have the same problem. Tried all the above nut still no working.
Tom
Best Answer09-12-2016 04:35 - edited 09-12-2016 04:36
Thanks for stopping by @tomlan43
! Thanks for trying the suggestions!
Are you syncing frequently? Since when did you start noticing the missing sleep data? Have you tried logging out and logging back in? Have you checked your sleep data on a computer instead of your phone? Didn't the restart make any difference?
Would you mind to be specific about what you've tried? (I mean step-by-step)
Best Answer09-12-2016 18:50
09-12-2016 18:50
Best Answer09-13-2016 05:02 - edited 09-13-2016 05:03
Hmmm...very strange @tomlan43! If you've tried the suggestion posted here I'll recommend getting in touch with Customer Support directly so they can do a deeper investigation and see where the issue is coming from.
Have a great day!
Best Answer01-17-2019 16:20
01-17-2019 16:20
Tho. You didn’t mention how to start sleep tracking in the app. This would be helpful please.
