12-09-2018
04:05
07:49
AndreaFitbit
12-09-2018
04:05
07:49
AndreaFitbit
I have just purchased my second Surge from a person in different Time Zone in Australia. I live in Perth, Western Australia (G+8), which does not have Daylight Saving.
The new Surge is from Victoria G+10 + 1(DS). The time displayed is the Victorian time IE G+10+1(DS).
My account setting is G+8. There is no provision for a Daylight Saving setting..
I have tied different settings and restarted the Surge several times to no avail. The displayed time is +3 hours out. Can someone help me please?
Moderator edit: format.
Best Answer12-09-2018 04:23
12-09-2018 04:23
Solved. My apologies if I have wasted any ones time on this. I changed thge time zone to another location and restarted the device. This worked so I changed it back to my Zone. This worked after the second restart.
12-09-2018 04:23
12-09-2018 04:23
12-12-2018 11:47 - edited 12-12-2018 11:49
That my friend @Maxon is the normal steps suggested, glad it worked
I've marked your thread as solved, so that it may help others.
BTW you could also have marked your response as a solution.
07:52
07:57
12-13-2018
07:52
07:57
Welcome to the Fitbit Community @Maxon. I'm glad to hear that changing time zone and restarting your device solved your issue. It's always a pleasure to assist you and you don't waste anyone's time since we got a solution. ![]()
Thank you for marking the thread as solved @Rich_Laue.
Keep on visiting the forums.
