02-28-2016 19:01
02-28-2016 19:01
02-29-2016 21:34
02-29-2016 21:34
02-29-2016 06:05
02-29-2016 06:05
Hey there @bilgolajon! That's weird, since you have tried some troubleshooting steps, at this point I recommend contacting support so they can investigate and evaluate your case.
Keep me posted! ![]()
Was this what you were looking for? Vote for it and mark it as an Accepted Solution!
02-29-2016 21:34
02-29-2016 21:34
08-09-2016 08:41
08-09-2016 08:41
Getting the same issue with my Surge. Just starting happening this week. I will contact support as well
08-15-2016 19:22
08-15-2016 19:22
Thanks for the update @MorrisonJ and @bilgolajon! @MorrisonJ I hope now you are back on track. Keep @CindyFitbit and I posted with the outcome! 🙂
08-22-2016 05:25
08-22-2016 05:25
Contacted support and since my Fitbit is just outside my year, there's nothing they can do about it but purchase another one. This is my second fitbit that has died in just over a year of purchase. My original was the Flex and it lasted about 14 months. So when I was upgraded to the Surge I was so happy. Only to be disapointed again that it's only lasted just over a year again. Not only has the one batter light gone off, but the screen no longer swipes too. It still tracks steps, etc, but is fading fast.
Best Answer08-22-2016 16:58
08-22-2016 16:58
Thanks for the update @MorrisonJ! I really appreciate that you shared your experience with Support. This feedback is really important for us since it help us to improve our policies and services. This has not gone unnoticed and be sure that I will pass this along.
Fitbit has been designed to provide motivation and help you to reach your daily goals to success. Please know that we provide feedback to our team based on community posts and we are always working on improving our devices and overall environment based on that feedback.
Best Answer08-25-2016 10:11
08-25-2016 10:11
Well I have recieved my final email from the support unit that there is nothing they can do for me since the Fitbit is just outside my 12 months. Its frustrating to think that I would have to spend another $300 to hope that lasts more than 1 year again. That's 2 fitbits pooched in just over a year each. I may try my luck with another brand at this point. Although my fitbit is still tracking my steps and HR, I can no longer use the functionality of it on my wrist as the swipe function on the screen no longer works either. It looks cracked, but its just the inside of the glass... it went cloudy one day and when the cloud went away, this is what it looked like.
Best Answer09-07-2016 08:39
09-07-2016 08:39
Thanks for getting back @MorrisonJ, as @LucyAP kindly mentioned we really appreciate this feedback. We appreciate that you took the time to share with us your experience and updates about your case with support. For reference about our policies you can always check Warranty & Returns terms.
See you!
