02-25-2017 02:56
02-25-2017 02:56
03-18-2017 09:56
03-18-2017 09:56
Nice to see that you're digging into the Forums @Steve_B, let me give you a warm welcome to our Community. Thanks for the fantastic suggestion @WendyB! ![]()
Sorry about Surge! Thanks for the troubleshooting steps that you already tried! I'd suggest trying the restart a couple of more times, while the Surge is plugged in into the computer.
Then try these steps to disconnect your Surge from your Fitbit Account and add it back, to see if this helps, usually indicates issues with the firmware update. If these doesn't help and you have a computer please add back your Surge to your Fitbit Account using the Fitbit Connect program on your computer via Wireless Dongle.
Le me know if this helps! ![]()
Best Answer02-25-2017 06:42
02-25-2017 06:42
You are restarting by pushing those buttons. So something is wrong and I would Contact Support
http://help.fitbit.com/?cu=1
Please let them know you have restarted it many times
Wendy | CA | Moto G6 Android
03-18-2017 09:56
03-18-2017 09:56
Best Answer02-26-2021 05:37
02-26-2021 05:37
@YojanaFitbit I tried everything in this post, but I can't get my Fitbit Surge to restart at all. It is disconnected from my account and from Bluetooth. Any attempts to restart the device are met with the blinking logo and no other response. Currently, I'm waiting for the battery to run down to see if it will reboot itself naturally. Do you have any other suggestions?
Best Answer03-15-2021 22:04
03-15-2021 22:04
Hi @Kimmi_P I'm not Yojana but I see you've waited a few weeks to hear back. If your device is in permaloop (only showing the Fitbit logo), quite likely something's wrong with the circuitry and usually unrepairable. You can try resetting but it sounds like you have. I've serviced hundreds of Fitbit Surges and if stuck on logo, never progressing, it's a lost cause 😞
