10-25-2016 05:53
10-25-2016 05:53
I had my Surge off for a week; recharged it fully and now the time is off and it won't sync. I've tried to reset it by pushing the main button and bottom right button but nothing.
Help!
04:19
04:46
10-26-2016
04:19
04:46
Welcome to the Community @Taoshel. Thanks for troubleshooting this inconvenience by yourself. I recommend restarting your Surge by following @MeylinP's instructions. After the restart process, follow @HelenaFitbit's instructions in the Having trouble syncing? post. By following these steps your time should correct itself. If it doesn't, change the timezone to a complete different one, sync your tracker, put the correct time and sync one more time. To change the timezone do the following from a computer:
1. Log into your fitbit.com dashboard and click the gear icon in the top right corner.
2. Select “Settings” from the drop-down menu.
3. Scroll down to the Time section and choose the time zone that best reflects your current location. You can also select 12-hour or 24-hour time display format here.
4. Sync your tracker to update your time zone.
I hope this helps, let me know the outcome. ![]()
