08-14-2017 00:57
08-14-2017 00:57
Good day, I just cannot get my phone and watch to sync. I have rebooted the watch and the phone numerous times and have also made sure I have the latest update of Fitbit on my phone.
Any suggestions please?
Jean-Marc
Best Answer08-14-2017 02:46
08-14-2017 02:46
Hi, @JMdB, has your Surge ever synced with your phone, or is this new behaviour?
You can check whether your phone is compatible here.
Fir steps to follow if your Fitbit isn't syncing see this help article
Best Answer08-14-2017 03:21
08-14-2017 03:21
Hi, I´ve the watch since last year and no Problems. Yesterday i got the message "Wartung" and now i´ve just a White Screen - nothing else. What can i do? there is no sync possible.
Many greetings
Pinkyfit
Best Answer08-14-2017 03:55
08-15-2017 23:59
08-15-2017 23:59
HI Julia, thanks for your reply. No it has always synced, this is new behavior. I will check your compatibility suggestion now.
Best Answer08-16-2017 01:17
08-16-2017 01:17
Hi, @JMdB, if it has always synced in the past, then compatibility should not be the issue. Please work through the steps in the article I shared above, and if you still can't get it going, I would suggest getting in touch with Fitbit Customer Support on contact.fitbit.com.
Best Answer08-16-2017 01:23
08-16-2017 01:23
Even I'm facing the same problem since today morning!! The surge is not ready to synch at all
Best Answer08-16-2017 01:32
08-16-2017 01:32
OK thank you.
Best Answer08-16-2017 08:58
08-16-2017 08:58
I've been having the same problem (not syncing). Started with the recent update. I've had my surge for a while now so I know my phone is compatible (LG G5). I've tried all the suggestions on fibit help page. But did not remedy the problem.
08-16-2017 11:18
08-16-2017 11:18
@Msjoys, @JMdB, @Pune, @Pinkyfit it seems there is a known issue currently of Fitbits not syncing with Android phones after the latest app update. Fitbit is aware and is working on a solution ASAP.
You can get more information on this thread
Best Answer08-24-2017 03:09
08-24-2017 03:09
HI Julia, do you know if Fitbit has solved this problem?
