Best AnswerWelcome to the Fitbit Forums @Pebbles72! You can start tracking your Runs, Hiking, out door cycling activities... with your Surge without the necessity of having your phone with you. At the end of the activity your Surge will display some stats where you can see data like: length of the activity, distance, heart rate, calories burned, steps (if applicable) and altitud. However, you will need to sync it in order to see the map. Once you have synced you will get the following information:
Hope this clarifies your inquiry.
