07-09-2021
14:08
19:16
07-09-2021
14:08
19:16
Hija, have had a Fitbit surge since Sep 2017. A fully charged battery is now only good for 45 mins use, which is not any good. Is approx 4 years the life expectancy for a Fitbit? If so, I find that very disappointing.
Kind regards, Alick
Best Answer08-26-2021 16:32
08-26-2021 16:32
Yes, @AlickN that's correct, 4 years is the maximum expected life of a Fitbit or any fitness tracker with a LiPo battery, they're only rated for ~3 to 4 years though some last for longer. I've replaced batteries in hundreds of Fitbit Surge devices and am happy to help you or any other member here with self-servicing. It's fun, easy, and rewarding! 🤗
New replacement Surge battery
09-20-2021 02:45
09-20-2021 02:45
Hello AlickN! I’ve been using a surge too for about a month now. So after 5-6 years,I took my surge out to use it but it’s battery lasted only 1-2 minutes. So I kept using it and charging it and after a week or two it’s battery was lasting 1-2 days. So just have patience and use and charge it regularly and your surge will work perfectly. Hope this would have solved you problem.🙂
Best Answer09-20-2021 02:48
09-20-2021 02:48
Hello Williger! Oh that’s nice that you service surges and I had a battery issue too but I charged and used it regularly and it just worked perfectly.
09-20-2021 10:00
09-20-2021 10:00
@Aayush00 that's awesome! Which kind of battery did you install? The one I shared above is 160mAh like Fitbit's original. Many aftermarket batteries are only 120mAH (shorter life).
Regarding your statement "approx 4 years the life expectancy for a Fitbit? If so, I find that very disappointing", put your disappointment into the battery technology, it's not Fitbit's fault. LiPo (Lithium POLYMER in caps in case the lady who'd insists they're LiON reads this post, as they're definitely not). Lipos last around 3-4 years 🤓
Best Answer09-22-2021 05:11
09-24-2021 14:23
09-24-2021 14:23
Excellent choice, @Aayush00 both batteries have benefits but for our Fitbit trackers, only LiPo batteries make sense because of their small size and weight. LiOns are larger and heavier.
Best Answer11-02-2021 16:50
11-02-2021 16:50
Do you sell the replacement battery?
Best Answer11-13-2021 20:07
11-13-2021 20:07
10:55
06:51
AndreaFitbit
12-16-2021
10:55
06:51
AndreaFitbit
Moderator edit: personal info removed.
11:00
06:52
AndreaFitbit
12-16-2021
11:00
06:52
AndreaFitbit
can we get the batteries in india please share the contact details
Moderator edit: format.
05-26-2022 06:37
05-26-2022 06:37
@srinivas.choice This battery is available in the US by a third party seller. I'm pretty sure this sender can't ship to India. But you can search Amazon India or another electronics site to see if you can find this model.
Laurie | Maryland
