05-30-2018
04:27
12:33
YojanaFitbit
05-30-2018
04:27
12:33
YojanaFitbit
I use my Fitbit daily, but have noticed over the last week or so that the battery runs down in less than a day.
I've followed advice from other topics, have re-started my device several times, and even removed it with a view to re-installing it.
However, each time I try to re-install the Surge, I pair the 4 digit number showing on my Surge to my phone, and each time the following message appears. "Error - The operation couldn't be completed. (com.fitbit.HTTP error 500)"
I have also re-booted my phone several time, with no success.
Please help, this is so frustrating.
I even went out to buy a Fitbit Iconic, but decided not to after inspecting it. Very disappointing cheap and flimsy looking compared to the Surge.
Update:
Appears to be paired, but now wont sync. This Fitbit is in danger of being binned.
06-01-2018 10:12
06-01-2018 10:12
Hi @Col1892, thanks for confirming that information.
As this type or errors are usually related to mobile apps needing the latest version, please check that both your phone or computer and Fitbit App are up to date. After the update, you'll need to try setup again.
Keep me posted.
05-31-2018 05:43
05-31-2018 05:43
Please clean the contacts
http://help.fitbit.com/articles/en_US/Help_article/My-tracker-s-battery-isn-t-charging/?q=not+chargi...
Then Do a Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
Also See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
https://community.fitbit.com/t5/Charge/Fitbit-charge-battery-problems/m-p/1323307#M53291
How can I Improve my Fitbit battery life?
http://help.fitbit.com/articles/en_US/Help_article/2004/?q=improve+the+battery&l=en_US&fs=Search&pn=...
If that does not help contact support
http://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs
Wendy | CA | Moto G6 Android
05-31-2018 09:28
05-31-2018 09:28
Thanks Wendy.
Charging is no longer the issue, cant get it to sync now.
05-31-2018 13:19
05-31-2018 13:19
Hi @Col1892, thanks for getting back and for following the suggestion that @WendyB suggested.
About the syncing issues please confirm that your Fitbit App and phone are up to date first, then you can follow these steps:
Hope this helps.
05-31-2018 14:28
05-31-2018 14:28
Hi Yojana,
I have tried your advice several times, yet am still getting this message......."Error - The operation couldn't be completed. (com.fitbit.HTTP error 500)" Sometimes the error code is 400 or 300.
06-01-2018 10:12
06-01-2018 10:12
Keep me posted.
