03-04-2019
00:09
11:24
YojanaFitbit
03-04-2019
00:09
11:24
YojanaFitbit
Had my surge watch just over a year now and it's starting to become faulty. First the buttons and now the touch screen don't operate. Frustrating as I can only see the time. Was hoping for better quality from this product. Have done the reset but no luck in getting a result. Not happy
Moderator edit: Updated subject for clarity.
03-06-2019
11:23
06:51
03-06-2019
11:23
06:51
I've noticed you are new around @joshnolan1, so let me give you a warm welcome to our Community. ![]()
Thanks for sharing with us the feedback of your experience and for the steps you've tried in order to fix the issues with your Surge. We strive for excellent customer service, and customer satisfaction remains our number one goal. I've checked with our Support Team and apparently they already took your case under their wings. Please keep an eye in your email inbox, you'll get some information about your case.
Please let me know if you need anything else!
Best AnswerMy Surge is well over two years old and the home button, when it works, only changes to Timer. Also, the band is almost torn off at the watch frame caused my needing to press very hard on the home button to get it to switch. AND, I have to use duct tape to keep the strap from tearing completely off at the holes. Great product concept, poor design and execution IMO.
My fit bit has done the same thing. I can’t get to my settings or my treadmill workouts. It’s like the watch is only working half the time. It’s so frustrating especially when you bought the watch to use when running and working out and only a a few options and buttons work! Help! I would like all buttons to work and to be able to have my treadmill option back!
06:19
06:45
03-13-2019
06:19
06:45
Welcome to the Fitbit Community @TXMike and @Ahawk! I apologize for the delayed response and will be glad to assist you with your button and touch inquiry.
To fix the button issue I would recommend to clean the part of the buttons, they can have dust or dirt on them that doesn't allow proper work. You can also try restarting your device.
There are no replacement bands for the Fitbit Surge.
Please let me know how it goes.
Best AnswerHow to clean the buttons? Unable to restart the surge because the home button does not function.
10:22
06:45
03-14-2019
10:22
06:45
Thanks for getting back to us @TXMike! I'll be glad to assist you with your cleaning buttons inquiry.
You can clean your Surge button with a tooth brush or a tooth pick. You can also use caned air.
Thank you for letting me know that you're not able to restart since button does not function.
Let me know if you have more questions.
10:39
06:45
03-14-2019
10:39
06:45
You're very welcome @TXMike! ![]()
Please let me know how it goes. Keep on visiting our community!
