04-28-2016 19:47
04-28-2016 19:47
Best Answer05-02-2016 04:55
05-02-2016 04:55
Hello @Iso1682, good to see you around in our community. I would recommend first to try a restart. In my opinion this is an issue related with the internal software of the tracker. I'm sure you know the steps for a restart but just in case you need additional help here are the steps:
1. Press and hold the Home and Select buttons (left and bottom right) for 10 to 15 seconds, until you see the screen flash or start to dim.
2. Let go of the buttons.
3. After your screen turns completely off, wait 10 seconds and press the Home button to turn your Surge back on.
If you seem to be having trouble restarting, simply hold down the buttons for a longer time; don't release them until you see the screen get significantly dimmer.
Hope this get you back on track and let me know how it goes!![]()
