01-15-2017 03:17
01-15-2017 03:17
How do I get details of my elevation when I bike in meters? I have the Surge.
01-16-2017 05:53
01-16-2017 05:53
It's great to see you in the Community @Genten! Welcome. You can see the details of elevation in your Fitbit.com Dashboard online using a computer, click on Log > Activity > Bike > View Details. Your Setting should be on Centimeters, find the Settings in the upper right corner of your Dashboard. (Settings > Advance Settings). ![]()
Please note that this information is tracked by using the option "Bike" in the shortcust of your Surge, since it requires GPS connection.
I hope this helps, I'll be around!
Best Answer01-16-2017 11:42
01-16-2017 11:42
01-17-2017 07:33
01-17-2017 07:33
Awesome to see you here again @Genten! Got it! You will find the option to delete you old Surge under Account > Tap on the tracker > Trash can. If you have a mobile device is almost the same Account > Tap on Surge > and delete the device. ![]()
You can also choose the option "Set up a device" from the Account section and during connecting your Account will recognize that you're replacing the Fitbit. For Setup instructions check this master post.
Have a good one! ![]()
