07-25-2018
14:57
05:28
YojanaFitbit
07-25-2018
14:57
05:28
YojanaFitbit
Well the end of my Surge is here. I purchased the first 1 when a major sporting goods chain closed and I got it at a very discounted price. It lasted just over a year and died but was replaced after contacting Fit bit. I knew then that when the replacement failed as much as I liked the Surge I wouldn't purchase another Fit bit again. I haven't posted often but read this forum religiously. Its apparent the products are not made to last. I'm now conditioned to have a tracker as part of my daily routine. While the Surge was failing, wouldn't sync,band bubbling and finally won't charge. My research leads me to Garmin or Samsung. I haven't decided but I do know It won't be Fit bit. Thank you for hearing me out.
Moderator edit: Format and updated subject for clarity.
07-26-2018 05:36
07-26-2018 05:36
Hi @Kevin.o, thanks for sharing your feedback. ![]()
Sorry you feel that way, please know that we do appreciate our loyal customers and if you change your mind about checking your options with our team I'll be more than glad to help you out with that. However, thanks for sharing this, our team receives your feedback and based on community posts we are always working on improving our devices and overall environment.
Thanks for your understanding.
Best Answer07-26-2018 05:36
07-26-2018 05:36
