Hi!
I've found several threads here on this topic but my issue is still not solved. I was charging my Surge when I noticed the display is flashing on the fitbit logo.
I have tried:
Nothing is working. As soon as I power back up, it resumes with the flashing logo. The heartrate sensor lights do not blink. There is no response on the touch screen. I have had and used this for about a year without any issues (too late to return).
Are there any other options?
I would Contact Support
http://help.fitbit.com/?cu=1
See what they can do for you. But sometimes doing several restarts solves the problem
Wendy | CA | Moto G6 Android
Welcome to our family @benchilcote, welcome! I'm glad to see you here. Sorry about your Surge, it looks like it got stuck you can try to "Set it up" with your phone or your computer. Please check the requirements and follow the the next steps:
Steps:
It's best to use a computer since your Fitbit is requesting an update. For more information to set it up with a computer check this post.
If this doesn't work follow @WendyB suggestion and contact Customer Support!
Good luck with your Surge! ![]()
