Hey there @tallbook681, thanks for visiting the Forums! That's odd! Have you tried the restart on your Surge. Follow this steps:
1. Press and hold the Home and Select buttons (left and bottom right) for 10 to 15 seconds, until you see the screen flash or start to dim.
2. Let go of the buttons.
3. After your screen turns completely off, wait 10 seconds and press the Home button to turn your Surge back on.
If you have trouble restarting your tracker, just hold down the buttons for a longer time; don't release them until you see the screen get significantly dimmer.
Your Surge should work normally now! ![]()
I'll be around. ![]()
