If you go to your device settings page (here) you can select the types of exercises that the unit will automatically recognize and the time which you need to be doing it to get the tracking to start. You can also manually start tracking by following the information here. You can also manually log an excercise - information here.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
