09-27-2016 15:42
09-27-2016 15:42
Best Answer10-01-2016 08:27
10-01-2016 08:27
Hello @SunsetRunner and welcome to the Community!
When you where on the treadmill where you on activity record mode or where you using the Surge normally?
This could make a difference when tracking over your steps. With the Treadmill there are a couple of factors to take into account with the tracker.
As the Surge is capable of tracking forward movements as well as body movements this is taken into account to measure the steps. In the treadmill however you don't move forward. Also the Surge needs arm movements to be precise so placing the hands on the bars can also affect accuracy. This is true for all of the wrist monitors. I invite you to read this thread discussing treadmill accuracy.
Another factor to take into account is that on the Treadmill the distance is estimated by calculating the number of steps and multiplying them with your stride length. So you need to make sure the stride length is properly set. It is calculated by your height by default but you can manually set it if you have measured or if you would like to.
Let me know if this helps. See you soon!
Best Answer10-01-2016 10:03
10-01-2016 10:03
