07-13-2016 09:33
07-13-2016 09:33
I have had my fitbit surge for 4 months and it has recently starting to act up (within last 2 weeks)
Issues:
1.)The active Run GPS wont find a signal.
2.) Fitbit wont sync to app due to Bluetooth not staying connected
3.) Battery use to last 2-3 days, now only last 1 day at best. I have used the active workout tracker every day so nothing has changed to cause this issue.
4.) when Fitbit is plugged into charger, it will start and stop charging every few seconds. Seems like the connection is poor.
Thanks
Best Answer07-13-2016 09:44
07-13-2016 09:44
Sorry no help just wanted to say ive had mine 2 months and have same issues its a piece of crap !!
Best Answer07-13-2016 20:02
07-13-2016 20:02
Best Answer07-14-2016 03:26
07-14-2016 03:26
Thanks, I have been charging mine via the wall socket so it's probably that ! Thanks for the reply ![]()
