08-22-2019 17:39
08-22-2019 17:39
why is my Surge no longer responds to finger swipe? pls help
noel
08-22-2019 23:54
08-22-2019 23:54
In the hope that it's just a software glitch, I would try restarting the Surge using this procedure: Help article: How do I restart my tracker?
If that doesn't work then it may be a hardware problem and it would be best to contact customer support. If they can't fix it then they can check your warranty status and advise on your options: contact.fitbit.com
08-23-2019 01:00
08-23-2019 01:00
Thank you Steve for taking the time to reply..
unfortunately I think my device has an expired warranty and the glitch is now internal to the system..
