10-01-2016 03:52
10-01-2016 03:52
Brand new Surge (and user).
Did 53 minutes of brisk walking on treadmill. Surge recorded 53 miintues of Active Minutes, but only .5 miles (when it was actually bit over 2.0) and only 1000 (ish) steps.
Only my 3rd day with this, and the other 2 days I walked on the treadmill recorded accurately.
I tried to manually log exercise to make up the difference but that seemed to muck things up and changed some of the stats that were in there (Active Minutes now show 0).
Anyone have any suggested troubleshooting or configuration settings to check?
Thanks in advance.
Best Answer10-02-2016 10:31
10-02-2016 10:31
As I have bee told in this tread, the distance is measured with the GPS. And you are actually not moving you out of the place. Well well, that what just comes up.
https://community.fitbit.com/t5/Surge/Setting-GPS-settings/m-p/1586351#U1586351
Rip
Best Answer10-02-2016 13:14
10-02-2016 13:14
Thanks for the reply - maybe I am misunderstanding how this works, I thought the GPS use was optional by specifically tapping to "track exercise". I didnt want to wear down battery unnecessarily since I was walking on a treadmill instead of outside.
I've had it for a few days and have only done exercise on the treadmill (walking) other than normal steps as part of my daily life. For the first few days it seems to have recorded the treadmill walking accurately.
Do I have it wrong? Shouldnt it accurately count my steps even if I am walking on a treadmill? Steps are steps, right?
Best Answer10-02-2016 15:24
10-02-2016 15:24
dingos8mybaby wrote: Shouldnt it accurately count my steps even if I am walking on a treadmill? Steps are steps, right?
Oh yes I believe that, but not the distance if you use the exercise/walk possibility.
Rip
Best Answer10-02-2016 15:37
10-02-2016 15:37
Under RUN there is a posibility TREADMILL RUN, are you using that?
Best Answer11-12-2016 07:55
11-12-2016 07:55
Hey @rip59, it is great to see you around the Community!
Remember that the GPS is not necessary if you are exercising on the treadmill since you remain on the same place, as @dingos8mybaby mentioned, that is why the distance may be affected and you can get a lower distance that if you were actually walking in an open place. Now regarding your other question, yes, you can use treadmill run, but remember that as long as you are on the same place there is no need to use the GPS.
Catch ya' later!
Best Answer02-18-2018 14:51
02-18-2018 14:51
Greetings. When I bike Imwas unable to locate the bike icon under the “exercise” tab. I believe that I’ve fixed that issue as a “bike”option is now available.
new issue: the GPS accurately records my path. It is displayed on a map. However, it displays the distance as 1.5 miles when my distance was closer to 12-14 miles.
Please help me correct. I want/need credit for each inch (ha).
chris
ketsac@netscape.net
