01-31-2018 15:48
01-31-2018 15:48
My Surge using the Eliptical activity records only half the distance that the machine I use records. The editing process only allows you to correct time. Is there a way to edit this.
Best Answer01-31-2018 20:21
01-31-2018 20:21
It will not be accurate on an elliptical as its not step based.
But you can add steps by using the Walking record to manually add them. But just beware manually added steps do not go to challenges or badges.
I myself just go with it.
Wendy | CA | Moto G6 Android
