03-12-2018 01:28
03-12-2018 01:28
Fitbit Surge's screen has gone blank from yesterday while its battery still have charge of more than half. When I press the button, it came back for a moment then again it got blank
04:41
08:27
03-12-2018
04:41
08:27
Hi, @ajay30, have you tried giving your Surge a restart? That can sort out many problems. You are usually advised to try this 3 times, as a single restart does not always work.
If after trying the restart 3 times you are still having this problem, then I would suggest getting in touch with Fitbit Customer Support on contact.fitbit.com. They can let you know what further options there are.
Welcome to the Forums!
